Jim Bowen
Loose steering wheel
this is for a friends car, corrado vr6 too.
he says the steering wheel wobbles up and down and that some pin is worn on the adjustable column?
is this a simple fix, hopefully it doesn't require a whole new column
You'd just need to change the pin. Mine actually came loose whilst driving, so the steering wheel was totally free to move up and down- quite a scary experience! :shock: I just popped it back in and used araldite on the end to hold in place.
It's easy enough to get to and swap out- just remove the lower steering cowling.
Has the araldite done the trick ok? Have the same problem with mine and used some loctite on the end of the pin, not been out in her since though. Lucky the pin popped out when I was parking and not when I was flying round a corner :shock:
