tribetype40
Electrical problems JUST saved from burning to the ground!!!
Phew, that was close. On my way home today I was getting flashed by everyone, pulling over I found I had no rear lights! got home and had a look about thinking it was just a bust bulb, but both lights? anyway tested the bulbs, one was good one was bad, so must be that one blew and popped the fuse.
Fitted a new bulb and replaced the fuse went back and checked the rear lights both working - great. However going back to replace the fuse cover I was greeted by a horrible smell. WTF! sticking my head in the footwell I could see the fuse was boiling!!!!!! quickly pulled it out but the car was full of smock by now and the lights were stuck on.
I quickly pulled the trim off under the dash and pulled the fuse box out to get a better look only to find a bunch of wires melted and still smoking. so opened the bonnet and quickly disconnected the battery. thats where I am know.
Cr*p
was wondering if anyone else has had a similar problem and if it was obvious what caused it.
Failing that I will have to pull it all of and chasae/rewire the whole lighting system (and any other damaged wires) so if anyone has cabin loom suitable for a '95 VR6 please let me know oh and a new fuse box as mine looks a little melted now!
Thanks for your help.
Doug
Crikey. Just in the nick of time by the sounds of things! Good luck getting it sorted out!
