cmr2payne 0 Posted November 23, 2007 I have just got a corrado and I have not dipped beam, All the other lights work correctly just not dipped beam, It looks like the loom has been monified at some point. Can anyone tell me which colour wire is the dipped beam wire and does anyone have an idea why it wouldn't work ??? Thanks in advance for any help. Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted November 23, 2007 If the loom has been modified with an uprated loom it could be a fuse or relay in the new wiring has gone. You'll be able to tell if you have an uprated loom added as there will be relays and fuse holders around the battery area. Not 100% sure on colour, but think its the yellow. Quote Share this post Link to post Share on other sites
cmr2payne 0 Posted November 23, 2007 Dub Nut Yes I have relays and fuse holders near the battery, thats part of the new loom Apart from the fuses new the battery and the relay, any other ones i should check Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted November 23, 2007 My bet is either a connection in the new loom has worked loose, or the relays have got water in them, both have happened to me a couple of times! Might as well check the fuses in the fuse box under the dash too, just in case! If it is the uprated loom that is dead you might be as well off making a new one yourself with 4 relays and fuses (1 for each sides dipped and main beams) its really not difficult to do, and theres guides in the WIKI to help you. Quote Share this post Link to post Share on other sites
cmr2payne 0 Posted November 23, 2007 Dub nut I owe you a beer :-), Was a faulty relay, Many Thanks for you quick help and advice. onto the next problems now :lol: Quote Share this post Link to post Share on other sites
