woz31 0 Posted November 29, 2007 Hi,has anyone got a easy solution to correct my speedo, I have fitted 3.2 tt engine and due to erratic tacho and other problems i now run 98 passat v6 synchro vdo dash panel, The easiest way would be to adapt channel 16, does anybody know the login code? Any other ideas would be good,cheers, PS the speedo under reads 100 on the clock is probably closer to 130 Quote Share this post Link to post Share on other sites
KipVR 1 Posted January 4, 2008 http://www.sempal.co.uk/SPAL_CANbus_interfaces.htm This is what you need, there are a few others out there on the market if you google it but this seems to be the best. Have a look at the '24V into a corrado thread' in the engine section, I've made a PIN out table, would appreciate it if you can add to it at all? Quote Share this post Link to post Share on other sites
