stevej
main beam headlight fuse keeps blowing
Hi
any suggestions for the above fault ?? any thoughts appreciated. is running a standard loom although i uprated the bulbs a long time ago. had no probs until recently,
cheers
Check for any exposed wire in the loom. It may be grounding itself out.
I had the same situation in my Mk3.
bulbs sometimes short out internally its worth a look , disconnect the lights and try that first if they blow fuses with the lights disconected the faults some where else :)
