h6 vwc
corrado wipers
hello, ive got a 94 vr6 corrado, and from time to time my wipers set themselves to full speed and don not slow down or turn off even in the off position. I have tried turning the car on and off again but it doesnt work! They just seem to sort themselves out after a bit of time, usually 10-15 mins in which time they knacker my aero wipers (full speed on a dry screen!!!). I'd appreciate any advice. tHANKS
hi
sounds like the relay is sticking to me pull it out when this happens and see ,as the relay will keep it going even with the ignition off
is there a relay for the front wipers? if so which one, i located the relay for the rear wipers and pulled it out, put it back in but wipers continued at full speed still. thanks
relay no 99 is the front intermittent wiper relay (19 on early cars) although your problem sounds like a worn wiper stalk which can make contact for the wiper circuit in the OFF position. Try wiggling the stalk about gently and see if you can trigger it to happen or stop when the fault occurs.
