Serial
Suspension advice needed -- FK Highsport damper replacements
The dampers (FK Highsport) on 3 corners of my Corrado VR6 are on the blink and need replacing, and I've been pondering my options. My main priorities are good handling and longevity of the components -- I'm a bit miffed that after only 2yrs of use the Highsport's have failed completely (not exactly "performance" suspension in my book) I'm not too worried about lowering it so the sump scrapes the tarmac or mega-sharp handling, but I would like to keep it a bit lower than standard.
* Replace the dampers with the same FK ones -- although everywhere I've rung so far about this seems to have stopped dealing with FK.. have they gone bust or something? (The springs are fine, it's just the dampers that need replacing.)
* Replace the dampers with some different ones -- I've heard Koni dampers are 'compatible' with the FK springs, is this so? Any others?
* The next option would be to buy a whole new coilover kit, e.g the H&R ones for around £750
* Finally I could go back to stock VW suspension (unlikely as I was quoted £950 for this job!)
Any advice would be much appreciated as I'm at a bit of a loss..! :o)
Tom
hi dude i would be very upset with 3 going thats does not sound right at all ?
here is the contact details of fk automotive from germany english speaking department
Tel. +49 (0) 7191 3275-110, Fax. +49 (0) 7191 3275-119
mite be worth a call you never know? they mite be able to supply direct
these are the Authorized uk FK Dealers: from FKs site
# Venom Motorsport
Ribchester, Lancashire
Phone: 01254 820005
# LMF Vauxhall
Market Harborough., Leicestershire
Phone: 01858 433 599
# Rimstyle
Kent
Phone: 01474 814469
# Performance Solutions
Northampton
Phone: 01604 232003
# Volksbits
Birmingham
Phone: 01214 724285
# Euro Performance Ltd.
Widdington, Essex
Phone: 01799 540900
good luck
http://www.corradosyncro.co.uk
Thanks for the info -- I'll give them a call and see if they can help.
I wonder if anybody has any opinions on replacing the dampers with some from a different manufacturer -- is this likely to cause problems with the springs not fitting, or incompatible spring/damping set ups?
how did you get on calling fk??
let me know if your stuck with them as i deal with them most days and could contact them if needed
barry
