darrensphatvr6 0 Posted January 22, 2008 Hi, Where do I start, the matrix heater went on my vr corrado so i had to replace it, and since then I have had a problem with my alarm and central locking. I've found bad connections to the alarm under dash so cut and fixed that but still my central locking will not work properly. It will lock the doors but will not open them :mad: Now I have the problem of opening the petrol cap because the central locking is not working properly, can anyone help me please? Thanks, Darren :? Quote Share this post Link to post Share on other sites
junkie 0 Posted January 22, 2008 I cant help on the central locking front but you can manually open the fuel cap from inside the boot, really awkward till you know where it is but there is a rod that needs sliding by hand behind the carpet on the boot side. Quote Share this post Link to post Share on other sites
darrensphatvr6 0 Posted January 22, 2008 I cant help on the central locking front but you can manually open the fuel cap from inside the boot, really awkward till you know where it is but there is a rod that needs sliding by hand behind the carpet on the boot side. Oh yeah, thanks for your help mate, anyone have any suggestions? Quote Share this post Link to post Share on other sites
darrensphatvr6 0 Posted January 22, 2008 Does anyone know which one is the relay fuse for the central locking on the fuse box as I suspect it might be that. Darren Quote Share this post Link to post Share on other sites
