kop10320178
can`t get my door open
hi, i own a 1994 rado vr6,
i can not get the drivers door open, i do not have a key to fit the door handle,
the central locking works on the passenger door and boot but on the drivers door the door pin does not pop up,
the same time this happened the central locking carried on for about 15 seconds as if it was still opening,
how do i fix this ?
how can i get my door open ?
thanx jay
Can you pull the pin up from the inside? Or does it not work at all?
With the central locking running on so long it sounds like an air leak in the CL system - possibly in the drivers door.
Find the leak! I'm sure there are other posts on here somewhere about tracing leaks in the cl system. Possibly by clamping different cl hoses until the system doesn't run on too long - then you know which part of the system is faulty. If you can get the door open and remove the door card you may be able to see the problem.
Obviously if you can't unlock the door with the pin from inside then you're going to have a problem. And I've no idea what to do then, short of destroying the door card.
