mindenboonhead
spoiler broken :(
My VR6's rear spoiler stopped working last week, it appears that no power is going to it as it is stuck in the up position...interestingly the sunoof no longer works along with the GPS system that was wired in by the cars previous owner....Any idea's?
Everything else in the car works spot on....
Start off with the easiest and cheapest solution! Check your fusebox for any blown fuses.
If it is a fuse blown it could be the spolier mech getting stiff and causing extra load. It's easy enough to re-grease it, and there's a guide on here if you do a search.
Welcome to the forum.
Can I be the second to say, use the search :D Seriously, it may sound unfriendly but most of the obvious stuff has already been asked and answered so you're probably better finding one of those threads and thanking the people involved rather than just asking the same question again.
