Gaz154
rocker cover gasket
looks like i've got a oil leak from rocker gasket in two places left rear above a circular indent and on the front right hand corner guessing i'll have to replace it is it diy or is it difficult
diy but have to remove inlet manifold. There are two types but you must have the early type metal rocker cover held in by bolts and flat gasket and replace any other gaskets you have to remove.
