jedi-knight83
brake fluid level?
trying to top up the brake fluid as it seemed a bit low. i poured in the fluid till it reached the maximum line and it straight away droped back to half way between min and max.... but it hasnt gone down anymore over the last 48hrs....is this normal?
There is a strainer in the reservoir. It takes a few seconds to flow through it. That would be my explanation.
Top it up again and see what happens. Bear in mind that you may have to remove some fluid if you change the discs and/or pads.
Gavin
yeah they feel fine and the fluid hasnt gone down anymore...its probably just another quirky corrado thing but i didnt want to just leave it with out knowing.... brakes are kinda important and all.
cheers
