dazG60 0 Posted November 22, 2003 NEWBY HERE CAN SOME1 HELP?...My c has a wet floor in the rear both sides...also i have no full beam..& my elec windows dont work...any ideas ??? :cry: Quote Share this post Link to post Share on other sites
h100vw 0 Posted November 22, 2003 Bad column switch, double headlight bulb and double spotlight bulb failure. Double fullbeam fuse failure. Not in any order. Wet floors could be leaky matrix, bad door seals. Bad door foils, the ones behind the door cards. When you next have some rain have a really close look at the door rubbers and the bottoms of the doors. Make sure the drain holes in the doors are clear. The 4 drains for the sunroof could be blocked to? Not sure if there are fuses or breakers for the windows. Do you have a Bentley manual, thats the beast to have.. Gavin Quote Share this post Link to post Share on other sites
dazG60 0 Posted November 22, 2003 hhmmm dont know where 2 start with the light thingy...if it was a leaky matrix woudnt the front footwell be wet aswell?? where do i find the fuses or breakers 4 the windows?? only had the car 2days...i knew of the probs when i bought the car ...didnt think they would take to much 2 sort out :oops: Quote Share this post Link to post Share on other sites
dazG60 0 Posted November 22, 2003 sorry dont have a manual...& it cold working on a car this time of the year in Norway :D Quote Share this post Link to post Share on other sites
h100vw 0 Posted November 22, 2003 The only time I did in Norway was in the summer. Beautiful. The fuse board is on the drivers side. The lid has the major fuses listed on it. So that should tell you which is which. Do the dip beams work ok? When you go to main beam do you end up with just the side lights?? With the ign on shield you window switchs, are they lit up in green? What do you do by the way, so we can pitch the advice at the right level. Gavin Quote Share this post Link to post Share on other sites
dazG60 0 Posted November 22, 2003 cheers Gavin, just been out 2 take a look at the fuses no cover on the fuse box they all seem ok :? there is however some off the relay boxes missing(dont know if there should be) the guy who had the car b4 me had a big f/off stereo in it & has taken it all out maybe he has blown some thing :? there is only the side lights working ....yes there r green lights aroud the window switches..im living in a place called voss ..maybe u know it the engish milatary come out here 4 there winter trainig im a painter :) Quote Share this post Link to post Share on other sites
h100vw 0 Posted November 22, 2003 Are you a brit? I met a lad at Oslo, working for SAS he was exRAF Tornados. He met a Norweigian girl when he was on detachment and ended up moving over there. I'll have a read of the bentley later and try and give you some answers. Cheers Gavin Quote Share this post Link to post Share on other sites
dazG60 0 Posted November 22, 2003 ok cheers Gavin & the rest who r tryn 2 help me ...yes i am a brit ..living in a place called Voss 1h 2omins from Bergen ..opp side of Norway 2 Oslo ..if some1 sorts out my car i can put them up 4 a few days ..loads of sexy norwegians gals...just take the boat from that place they call Newcastle ....LFC 4EVER 8) Quote Share this post Link to post Share on other sites
h100vw 0 Posted November 22, 2003 I take it you are a Scouser then. I live in Newton le Willows near Haydock. Although I am from York originally. I rated Oslo highly for the 'scenery' :lol: How did you end up in Norway? I was on a contracting job at Gardermoen. Top working conditions, defo the best contracting job I have had. Really easy going people. I lived in a bedsit the company provided, pretty close to the Palace. It was like pages 25,26,40,41 and 53 out of the IKEA catalogue!!!!!!!!! :shock: I'd go back but the tax was tremendous and beer was proper pricey. Even more than London nightclubs. :shock: :shock: info from work in the morning Gavin Quote Share this post Link to post Share on other sites
dazG60 0 Posted November 22, 2003 No mansfield mate & a few years in Benson (between Reading & Oxford) found my girlfriend ..well x now in Henley on thames ..au pair...had a kid moved to Norway ..yes the beers pricey but when u earn the wages its not all that bad---Darren Quote Share this post Link to post Share on other sites
h100vw 0 Posted November 22, 2003 So you were in the Mob then. I did my time at Cosford, Finningley(God rest its soul) and St Mawgan. Where did you get the diagrams? online? send me a link and I'll point you right. Gavin Quote Share this post Link to post Share on other sites
Henny 0 Posted November 23, 2003 My c has a wet floor in the rear both sides Check the seal around the top of the boot lid. Remove the rear seats and have a look under the carpet in the back of the car, there's several rubber gromets around there which, if missing, could allow water into the car. Check that your rear wash/wipe works. If no water is coming out (and it's not frozen! :lol: ) then the pipe could have split/come off and could be leaking water into the rear of the car. Check the drains on the sunroof, there's one in each corner. It means dropping the roof lining out, but if one of the rubber tubes has come loose then it could be leaking into the car rather than draining out as it's supposed to. :? If the guy you bought the car off had a big stereo, he may well have put some random holes in the floor to hold down amps and the like, it's worth getting under the car and checking for these as well, as it only takes a small hole to let a lot of water in! :? if it was a leaky matrix woudnt the front footwell be wet aswell?? yup. If your front carpets are dry, then it's unlikely to be the matrix! 8) Hope this helps.... Good luck! 8) Quote Share this post Link to post Share on other sites
dubster82 0 Posted November 23, 2003 with the water in the bacj could also be even if your missing the rear VW roundel. water gets in the hiles. it has been known to rust rear panels too. or even if you have the badge bu the lil blue grommets missing Quote Share this post Link to post Share on other sites
dazG60 0 Posted November 23, 2003 ok ive dry`d the carpet out gonna wait till it rains again-which it does a lot this time of the year-...i found what looks as thou it could be a water mark on the seat..& what im thinking is may some1 has left the s/roof open bcause there is only water in the f/well at the back ! ive check every where else ,dry as a ....1Q thou the 2 drain pipes that run from the back of the s/roof where do they go ??is it down the side pilers ? Quote Share this post Link to post Share on other sites
