dazG60 0 Posted November 22, 2003 Can u help?? my speedo is working but its not adding on the miles (or km as i have )whats the prob?? :idea: Quote Share this post Link to post Share on other sites
VR6 0 Posted November 22, 2003 Is it a digital mileage read-out? Quote Share this post Link to post Share on other sites
dazG60 0 Posted November 22, 2003 No i have a 89 G60 Quote Share this post Link to post Share on other sites
dubster82 0 Posted November 22, 2003 hmm. gearing brok on the readout? :? Quote Share this post Link to post Share on other sites
Henny 0 Posted November 22, 2003 Dubster82's probably right... On the end of the shaft that holds the numbers for the milage read-out, there's a little gear that sometimes comes loose (or is "adjusted" to clock the car... :roll: ) which will stop the milage changing... If it's just slipped, it's not too bad a job to sort it out... If it's damaged, then I'm not sure how you'd go about fixing it/ getting a new one... :? Quote Share this post Link to post Share on other sites
dazG60 0 Posted November 22, 2003 ok so i have 2 take out the instrument panel (clocks) out of the dash & have a look? is it a easy job ? Quote Share this post Link to post Share on other sites
h100vw 0 Posted November 22, 2003 Press the trip reset again. It might be stuck half in/out?? Gavin Quote Share this post Link to post Share on other sites
dazG60 0 Posted November 22, 2003 ok thanks 4 the help lads try these tommorow cold :shock: & dark now Quote Share this post Link to post Share on other sites
chubbybrown 0 Posted November 22, 2003 the wifes milometer on her mk1 golf would stop if the trip hadnt been reset properly at 163K :infinity: Quote Share this post Link to post Share on other sites
