pwoods76
Central lockin
Ok im fairly new to the Corrado but im havin probs all ready!
Firstly the drivers door wouldnt unlock at all! the alarm looked like it was tryin to and the key was pushin the pin up slightly but not enough. Ive nopw managed to completley pull the pin out ( to heavy handed) i think its the door mech its self which seems very stiff, since this the central locking now refuses to unlock with the key or alarm it only locks. I took the vacum plug of bottom of central locking actuator and it only sucks never blows? (no pun intended) but now the actuator actually lights up as if something inside is fuseing or similar. Has anyone had anything similar? oh the pass side or boot dont unlock either, just didnt know if it was the central locking pump , the actuator or something else? Oh and where is the fuse box on a 16v k reg? that shows how new i am!
Thanks in advance!
could well be the pump has run out of puff!!
its in the boot, behind the card covering drivers side rear wheel arch
