Rpmayne 0 Posted March 9, 2008 Just thought I'd post this for searching as I found out why my central locking / total closure was not working via the drivers door lock / switch. I took the drivers door card off and checked the supply to the lock switches. Seems that VW split the supplies via a solder joint in the loom sitting in the bottom of the door under the lock (describes this in the Bentley CD manual). As the insulation had been stripped back water had got in the joint and wires had corroded and broken. Connected them back up and all good. Quote Share this post Link to post Share on other sites
