camper driver 0 Posted March 17, 2008 Ok daft question. Indicator is bulb blown. How the hell do you get to the indicator????????? Embarrased :help: ! Quote Share this post Link to post Share on other sites
Dec 1 Posted March 17, 2008 Front, side or rear indicator? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 17, 2008 Either way it should tell you in the instruction manual! Quote Share this post Link to post Share on other sites
VR6 0 Posted March 17, 2008 Front ones pop out and the fogs unscrew .. or the other way round. Either way, the most obvious one just pops out. Side repeaters you need something like a credit card to slide behind the lense (from the back of the car to the front ... from memory, which was years ago), and there is a semi-barbed prong which needs to be pushed and the lense will pry out. Be careful not to disconnect the wire from the bulb and lose it down the wing. /Waits for new thread: How do I get the indicator wire back from inside the wing? :scratch: Quote Share this post Link to post Share on other sites
Dec 1 Posted March 17, 2008 /Waits for new thread: How do I get the indicator wire back from inside the wing? :scratch: Remove the bolts at the back of the arch liner. Gives you enough room to get your hand in there and retrieve the lost wire! :wink: Quote Share this post Link to post Share on other sites
camper driver 0 Posted March 17, 2008 Cheers guys. Its the front nearside. I take it that the whole indicator just pulls out then? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 17, 2008 yeah the whole lense comes off from the front, put a screw driver or something inbetween the fog and indicator and prise the indicator towards you. Quote Share this post Link to post Share on other sites
