Rich H
Tilt but no slide
Sunroof on my Corrado will only tilt. When the slide button is pressed and held it appears to be pulling one side more than the other and therefore not opening. Anyone have any ideas on what need sorting??
Thanks
Rich H :roll:
Sounds like one of the bits that attach the cable to the mechanism has snapped...
Quite a common one this... :?
There's a repair guide by Kevhaywire HERE 8)
Whatever you do, dont try to keep motoring the sunroof back. It's probable that you will eventually scratch the paint on the sunroof panel, and even worse, if it jams in open position will make it all but impossible to fix it! (seriously). There is also an excellent guide on the Corrado Yahoo Group on how to fix it. Not an easy job, but not as bad as it seems at first either! Helps a lot if you have a Bentley manual to consult.
Mark
