vrcorrado
Broken Corrado!
When you turn the key, the dash LEDs come on, I can hear the electric fuel pump start, but no starter motor, no turnover etc. I think the immobiliser is working ok, it still lights correctly etc and seems to disarm ok (constant LED). Battery seems fine.
My first thought was that it is a faulty ignition switch
any help would be great
Cheers
It could be a faulty ignition switch they tend cause odd things when they go wrong. But it does sound a lot like a dodgey immobiliser. Will it start with jump leads?
could be ignition switch.
mine cut out while i was pulling away hard in 1st gear. ugly noise and everything stopped. then the wires started smoking. :shock: :cry:
