oli1vw
recommended Halo headlights??
Hi
I am considering adding a new set of headlights ( and upgrading lighting loom ), can anybody recommend a good manufacturer of halo/angel eye headlights to fit M reg vr6 corrado.
Thanks
Oli1vw
inpro i have heard bad things about sonar , unless some one has them on here for some first hand knowledge on them,
i have black inpros and the quality is as good as oem i put headlamp protectors over them to so the lens dont get smashed
the only thing i dont like is the angel eye side lights so i disconnected them and relocated my side lights to inside the indicators
each to there own thou as with these headlights full stop
i did not due the conversion for looks , more for the performance of them with hid conversion and the perfect beam image a projector light gives
Hi Paul
Cheers for the photo, black is definitely my colour, the std set-up is pretty poor for night driving, just having a problem finding a set in UK.
Oli
Hi Paul
Oli
hi mate i got mine off a guy in germany off fle bay
thats the only way i could get a set in black
i think off the top of my head it worked out about a tenner more
or you could paint the chrome ones there is a set on ebay right now i noticed
good luck :salute:
this was were i got them
http://myworld.ebay.co.uk/oemgermanparts/
Hi i am looking into inpros but i am a novice and was wondering if you have to do alot to fit them and if so what? :confused4:
thanks
thanks
I think all you need is an uprated headlight loom, which is a piece of pish to fit. Other then that they just fit where the old headlights where, same fixings. Jobs a good un
hi
you can straight swap them , the inpros have an oem plugs they are 100% plug and play ,you even use the same adjusters out of the original lights in them .
but as with most older v.a.g. cars the headlight loom should be uprated for maximum voltage at the bulb.
