dazG60
heater resistor
Is the heater resister i(the 1 that makes it work on 1234 )n the blower the same as in any other vw? :?: reply needed tonight if poss... :D
It may be the same as one out of a Passat, but I've never tried... but it's definately not the same as a Golf one, or any of the other VWs the same age as a 'rado as they all had 3speed fans...
If yours has stopped working on all speeds except 4 then you've blown the thermal fuse... They're not expensive, but I have no idea where you'd get one from in Norway... :?
You could do a temporary bodge (like I did!) by soldering a bit of 13A mains cable in instead of the thermal fuse until you can source one out there... :? It's not very clever, but it'd make the fans work again! :roll:
The fuse is the smallish silvery cylinder with a wire at each end, at the top of the big resistor pack.
If this has blown, then the odds are that the fan's bearings are shot which has caused the resistor pack to over heat and blow the fuse. The fan motors are the same as MKII Golf. 8)
Yeah, I'm pretty sure my motor was shot when it took out the resister, it was still whinning when I got the new rheostat so I used one out of a golf...
got a new rheostat today from a elec repair shop paid around 37kr-£3.50 fited it...problem solved ...thanx 4 the help again boys :D
Thanks to you guys and the yahoo forum I saved £162 today. The local stealer quoted me £178 for a new fan and resistor. In Iver their are 4 scrappies right next door to each other, I got a fan for a tenner and a trip to Maplins yielded 2 thermal fuses (49p) each + soldering iron (2.99) and solder. An hour later I have a working fan and it's quiet. In the queue at Maplins was an engineer who told me how to solder.
Cheers.
Rik.
Cheers.
Rik.
You did very well to solder the thermal fuse in place - the heat from the soldering iron usually trips the new fuse.
Steve,
Didn't think about it, must be my lucky day, or it could be the advice of the guy in Maplins, who told me to apply solder to the target first. The bit that grips the wire I crimped by bending the wire on the fuse round and then dolloped on the solder.
Hit the "nail on the head" there - I'll have to remember that when mine needs doing.
Cheers.. :D
its funny i did that as well ,put the solder on first----i also bought a rheostat that could with stand a little bit more heat
