james_c2 0 Posted May 18, 2008 recently fitted a new spoiler mech and motor as the original was broke spoiler goes up fine on the button, but wont come down also not 100% sure it was allways going up automaticly anyideas, could it be the spoiler control module needs replacing? should the spoiler be able to be dropped by the switch? cheers james Quote Share this post Link to post Share on other sites
joedakio 0 Posted May 18, 2008 not sure what the problem is, however i can tell you the switch overides the automatic mechanism so should lower the spoiler at any time. Quote Share this post Link to post Share on other sites
james_c2 0 Posted May 18, 2008 cool, cheers for that going to see if when pressing the switch to put the spoiler down sends any current to the motor, hopefully that should help narrow down what it could be Quote Share this post Link to post Share on other sites
mr.ots 10 Posted May 18, 2008 not sure what the problem is, however i can tell you the switch overides the automatic mechanism so should lower the spoiler at any time. I can't lower the spoiler on mine with the button if I'm travelling above the automatic raise speed, only when I'm under 56 mph. Quote Share this post Link to post Share on other sites
chubbybrown 0 Posted May 19, 2008 spraying some oil down the tubes wouldnt do it any harm Quote Share this post Link to post Share on other sites
james_c2 0 Posted May 19, 2008 pushed the black bit in today to see if when the spolier went up and down when driving, noticed as soon as i started the car the spolier raised, so does this mean the control module has gone?? when winding it up and down manually it goes up smooth, same when it raises automaticly/of the switch Quote Share this post Link to post Share on other sites
Slimg60 0 Posted May 21, 2008 Inside the mechanism is a pair of micro switches. Mine had a similar problem and it turned out to be the microswitches had clogged with grease and gunk. Hope this helps and good luck!! Quote Share this post Link to post Share on other sites
