radness
Horn and fuse box
Guys, i'm frustrated with the search function on this site so i'm resorting to asking :)
Where is the fuse box location on a 93 corrado?
Also, my horn has stopped working all of a sudden :( any ideas waht it could be? i thought it might be a fuse.
The fuse box is located in the drivers side footwell just above where your right leg would be.
In reference to the horn not working....check the spade connectors on both the horns which are located behind the front grill.
If you have no joy there then you will need to have a look at the horn push switch in the centre of the steering wheel.
Thanks ! :D
Found fuse box, took steering wheel cover off and reconnected the wire for the horn, all works!
You rock :notworthy:
Thanks ! :D
No worries.....glad u managed to sort it :)
