Jon_vr6 1 Posted May 26, 2008 Hi as the title ive been told my anti roll bar drop link is causing the knocking noise when going over bumps so going to replace both sides anyone know the part numbers needed? Also while im at it i was going to get some new wishbones fitted as the mechanic said that the bushes are worn so rather than getting new bushes ive been told to replace the whole wishbone as the bushes are an arse to get out so part nu,bers for both sides of these as well please? Also is it worth replacing the bolts etc while im at it or should the old ones be fine ?? Many thanks :salute: Jon PS I presume VW is the best place to get the parts rather than gsf? Quote Share this post Link to post Share on other sites
Toad 0 Posted May 26, 2008 Wishbone Left 1HO 407 151 A Wishbone Right 1HO 407 152 Drop link 535 411 315 Hex Bolt for above N 019 504 3 Bottom Ball Joint 1H0 407 365 Get new bolts while you're at it. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 26, 2008 Whats that bottom ball joint?? Ive been told my ball joints are ok! Do i still need new ones? Also how many bolts hold the wishbone on? Quote Share this post Link to post Share on other sites
Toad 0 Posted May 26, 2008 Ok, ignore the bottom ball joint... Its the joint between the end of the wishbone and the hub, and allows the hub to pivot and move up and down. There are 2 bolts holding the wishbone to the subframe (19mms?) one horizontally back to forwards at the front of the wishbone, and one vertically at the back. There are 3 10 or 13mm bolts holding the ball joint to the wishbone. The drivers side needs the engine jacking up or the sump removing to get the wishbone off. Quote Share this post Link to post Share on other sites
