stevef182 0 Posted May 27, 2008 every now and again my vr wont start, it wont even fire..nothing..but it only happens occasionally. when i turn the ignition on i can hear the fuel pump prime and all relevant lights come on but it wont turn over, there is literally nothing.. so im guessing its either the ignition switch or the starter motor..i can hear a clicking coming from the dash when i turn the ignition and a faint buzz which im guessing is coming from the ignition switch, which leads me to believe its the starter motor but this is only a guess?? any help welcome as i think the guys at work are getting sick of bump starting me!! Quote Share this post Link to post Share on other sites
nemesis360 0 Posted May 27, 2008 Id go with a new ignition switch first, I have to change them all the time at work. Quote Share this post Link to post Share on other sites
stevef182 0 Posted May 27, 2008 really? despite the symptoms that i described? Quote Share this post Link to post Share on other sites
nemesis360 0 Posted May 27, 2008 Yeah the switch wears and it wont quite click over onto the last stage even when the keys fully turned, Id always look into probs with the switch before the starter, as I said I change loads of switches and not many starters. but without looking at the car I cant be 100% sure. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 27, 2008 Have you tried 'jiggling' the key when this happens?? If it's just started happeningmore in the hot weather I'd say it's mre likely to be the starter solenoid sticking but i'd still change the switch anyway if it's not one of the new black 6N0 parts. Quote Share this post Link to post Share on other sites
waynos 0 Posted May 27, 2008 ive got the same problem on my g60, bought a new ignition switch and swapped the stater for the one off my 16v and it still did it. i did notice my earth strap from the battery was going to the starter motor mounting bolt rather than the bracket on the gearbox like the 16v. swapped it to the correct place yesterday and its been fine (fingers crossed). it was wierd because if you jumped it from another car it would start straight away! (its got a new battery too) Quote Share this post Link to post Share on other sites
stevef182 0 Posted May 27, 2008 Supercharged said: Have you tried 'jiggling' the key when this happens?? If it's just started happeningmore in the hot weather I'd say it's mre likely to be the starter solenoid sticking but i'd still change the switch anyway if it's not one of the new black 6N0 parts. yeah i have given it a right good wiggle and nothing..but then 15 mins later i try and it starts..and it has definately just started happening since the sun has been out! but as you said maybe repalce the switch first and see if it cures it, although ive heard the switches are a right pain in the arse to change?? Quote Share this post Link to post Share on other sites
stevef182 0 Posted May 27, 2008 does anyone know if there is anything i can do to test which part is faulty next time it happens?? Quote Share this post Link to post Share on other sites
waynos 0 Posted May 27, 2008 if you change the switch and it happens again get some one to put a multimeter from earth to the red/black wire on the starter. turn the key.if you dont get battery voltage at the meter theres a wiring fault.if you do its the starter or solenoid Quote Share this post Link to post Share on other sites
stevef182 0 Posted May 27, 2008 waynos said: if you change the switch and it happens again get some one to put a multimeter from earth to the red/black wire on the starter. turn the key.if you dont get battery voltage at the meter theres a wiring fault.if you do its the starter or solenoid thanks mate, but have already checked that and got battery voltage so is definately not a wiring fault..i meant is there any way of telling wether its the starter motor or ignition switch?? Quote Share this post Link to post Share on other sites
waynos 0 Posted May 27, 2008 erm the only other thing i can think of is to get a cable from the battery positive and touch it to where the red/black is on the starter.So you will be bypassing the switch in a way. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 28, 2008 ^ Deffo the soleniod on the starter motor thats gone there, new exchage starter from VW is the way to go! Quote Share this post Link to post Share on other sites
stevef182 0 Posted May 28, 2008 Supercharged said: ^ Deffo the soleniod on the starter motor thats gone there, new exchage starter from VW is the way to go! to be honest i think that is what i would have changed first anyways as it seemed much more the likely culprit due to the sympotms, but out of interest what makes you say that it is definately the soleniod/starter motor? Quote Share this post Link to post Share on other sites
stevef182 0 Posted May 28, 2008 and waynos, thanks for your advice too! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 28, 2008 Quote to be honest i think that is what i would have changed first anyways as it seemed much more the likely culprit due to the sympotms, but out of interest what makes you say that it is definately the soleniod/starter motor? Just the way it's got worse in the hot weather and the fact it's sometimes ok after 15 mins and also that your getting the 12v feed from the ignition switch to the plug down there... can't really be anything else unless you have a (very) bad connection somewhere on the battery circuit. Next time it happens and refuses to do anything, get a large breaker bar or pipe and hit the solenoid with it (hard) Quote Share this post Link to post Share on other sites
stevef182 0 Posted May 28, 2008 Supercharged said: Quote to be honest i think that is what i would have changed first anyways as it seemed much more the likely culprit due to the sympotms, but out of interest what makes you say that it is definately the soleniod/starter motor? Just the way it's got worse in the hot weather and the fact it's sometimes ok after 15 mins and also that your getting the 12v feed from the ignition switch to the plug down there... can't really be anything else unless you have a (very) bad connection somewhere on the battery circuit. Next time it happens and refuses to do anything, get a large breaker bar or pipe and hit the solenoid with it (hard) ok will do..thanks for your help mate..gonna put up a wanted post just incase anyone has one spare but if not will do the exchange starter from VW. Quote Share this post Link to post Share on other sites
Fulltimejunglist 0 Posted August 29, 2011 This may be my problem as my car is not starting, it would after trying the key a few times and now does nothing. Where is the solonoid on the starter, so i can go and take my anger out on the bugger. Any help would be appreciated. Thanks Quote Share this post Link to post Share on other sites
RW1 0 Posted August 30, 2011 Follow the thick red battey lead down onto the starter body. The small cylinder unit. :) . Quote Share this post Link to post Share on other sites
buttles 0 Posted August 30, 2011 Case of my favorite 'starter motor relay mod'! Since relaying power directly to the starter solenoid not had the dredded hot start click since Quote Share this post Link to post Share on other sites
wy906 0 Posted August 30, 2011 My car got the same problem sometimes! :D Quote Share this post Link to post Share on other sites
Fulltimejunglist 0 Posted August 30, 2011 "Since relaying power directly to the starter solenoid not had the dredded hot start click since " aha sorry but how do i do that? I only worked out where it was today. I know little about car but always fix mine myself, hence why its sitting not woring at the moment. I will have a look at it gie it a whac see if it helps, would it be best to ust change this? As at the moment my car ust clicks at me, its the 12 relay, number 67 which is clicking. Also, how do i remove the starter, ive rear i may have to remove the drive shaft so as to access it, is this true? I have a 1.8 16v also, if anyone has done this please help. Cheers RW1 Quote Share this post Link to post Share on other sites
buttles 0 Posted August 30, 2011 http://the-corrado.net/showthread.php?41192-For-those-with-hot-start-problems-lil-update&highlight=hot+start+problems+-+lil+update Guide there shows how to use a relay to send battery umph to the solenoid. Did mine years ago after er, years of hot start nothingness. Neil Quote Share this post Link to post Share on other sites
Fulltimejunglist 0 Posted August 30, 2011 thanks mate, it is annoying i have to say. I also have a strange buzzing coming from what i think might be the distributor, what would this mean? that or its from the coil pack, both close and im on a main road so its hard to hear which one is making the buzzing. Too many buzzing noises on the car at the moment :@ Quote Share this post Link to post Share on other sites
