Tedb
2.0l 16V Air Intake system
Each time I change my Air Filter it is contanimanated with oil, just on the top of the filter in the centre, seems to be coming from the Fuel metering system, anyone know why this happens?
Cheers Guys
Most likely cause is the crank-case breather pipe, which runs from the front of the block to the top of the airbox. That tends to carry a bit of oil into the air intake pipework.
Cheers for that, I'll give the pipe a good cleanout and check it again in a few weeks to see if it's the same.
Thanks
mine does this aswell as i found out 2nite it blow all the oil out of what seems to be that pipe that goes under the air fliter wich connects to a lil sencor and a vave and some oil has enterd the air in take because the spark plugs were coverd in oil any ideas what it could be would be off help.cheers.any help at all would be great full
mattcorrado, oil on the filter / intake system has already been explained above. It's the positive pressure crankcase breather system and is designed to decrease pressure buildup below the pistons.
