KeithC
Corrado Track Car Project
Looks good Keith!
will that rack mount on the Corrado frame properly, as it needs 2 bush mountings as opposed to 1 on the standard Corrado item?
Also, that looks like a Mk2 golf subframe? I had some trouble with one of those and decided not to use it in the end, but I can't really tell if it's a Mk2 item from that photo so maybe it is a Corrado one :salute:
So, what's the plan for drivetrain, suspension, brakes etc? :clap: :grin:
That's an awesome shell prep.
wish i had the time and funds to take mine that far!
where's your cage from? looks very custom cages to me?? i haven't really seen any other options for corrado shells apart from custom stuff.
Yep rack and frame both fit.
Am tinkin of KW 3's or H&R Cup kit, not 100% yet tho. Have Vibretech bushes fitted to axle and wisbones now..
Prob go for sum nice Willwood or AP 4 or 6 pots, not gettin to big of discs cause car should be less than 1000kgs
no need to over kill..
Have to get custom driveshafts made up aswell as engine mounts..
Yep the cage is Custom Cages
A mate has a set of the new 17" lightweight OZ's was gonna paint them black if i paint the car white.
Can't deside whether to paint it white or sumting else now?
Any1 any thoughts???
looks awesome!! :notworthy:
I like how sneaky you're being with the engine, but i'm almost positive i know what that is. haha
as for the color I love this one (unfortunately the name escapes me)
the owner swapped out the stock wheels with black racing wheels & it looks amazing.
I'll find the name tomorrow if you like. The picture doesn't do it justice.
** i believe it's atlas grey **
Long overdue update
Sum of the parts
Back from paint
S7300189Small.jpgms/i207/vwgolfmk1/Corrado%20Track%20Car/S7300190Small.jpg[/img]S7300187Small.jpgS7300186Small.jpg
Engine in
All subframes, bumper brackets etc etc sandblasted and painted
Steering colum, pedalbox and gearshifter all in
Threw on the wing, bumper and wheel to see how it sat. am pleased :-)
Driveshafts are measured up and are bein made up this wk aswell as the rad.
Got a good jump on the wiring
Got the fuel system all plumbed up and finished
Started her up for the first time, turned kill switch and ignition switch. Fuel pump primed, crossed my fingers
and pushed the start button :clap: started first time :grin:
its very loud as hav no down pipe and exhaust as yet.
Fitted the boot wit spoiler and lights
Spoiler fixed in this position as no need for it to be electric anymore (less weight)
Looking good!!!! :D The shell looks great. It'll be great to see what results you get.
Will you be able to weigh it? I would be intresting to know how much weight you have lost.
Its mainly for trackdays but might do TimeAttack but not sure yet.
I intend to do 1 or 2 trackdays over your side of the water at sum stage
aswell as the Ring.
I'll have a fair idea of the weight when i get her weighed before i order the
Competion KW's.
Keith, did you fit the cage yourself? - i have picked up the same cage today from a mate who wont be using it and according to the custom cages site the tubes should all be profiled at each end - this ones just straight cut, and it should come with a cd and mounts, came with the floor mount plates but no cd, did you recieve any of this with yours? what does the cd contain?
Awesome build mate, its what i was/am doing to mine, but gotta change the ideas slightly from seeing yours, been watching it over on clubgti.
wow! i wanna get my cage in sooo much now i've seen this, it looks hard as nails standing still... limited rear visibilty though :lol: good progress mate
Why do you need to see behind you its the same car that you will have just waved to as you went past. :lol:
yep true! You decided what your doing with yours si?
Yep, see the pictures above, its pretty much the image i have been building up in my head, then i see this nice motor on clubgti.
Basically
Custom Cages or homemade similar by me and a mate.
Flocked dash
2 nice seats [buckets] most likely conversation stoppers
20v and silly power
6 speed O2M
Quaiffe or similar
Maybe SQS sequential shifter which may mean dogbox
The same wishbones etc as above
Fancy suspension, also looking into independant rear suspension
I was going white but not Corrado white, undecided on colour
Fuel cell in car
Carban fibre bonnet, boot, roof
Lots of dials in carbon dash insert
Suede steering wheel, mine retrimmed
Compo wheels
Biggerbig brakes
Still some stuff to think about but thats the basics. :ignore:
Few more updates.
Oil sensor and baffle installed in sump
New inlet manifold with longer runners
Got dash finished up apart from one guage i'm waiting for along with a new tacho. Previous one woz piece of crap
Also fitted USB connector on dash face for connecting up laptop for mapping etc
Just fitted one latch on boot
And a few more pics
Few more updates
Exhaust all done with manifold heat wrapped
Dash all finished up along with a new Tacho
New Sparco Corsa seat fitted
