Fat Tony 0 Posted December 28, 2003 Does the G60 have a fuel cut off switch and if it does how can you test this is working (if it does have one) cheers Quote Share this post Link to post Share on other sites
morpheus20170 0 Posted February 5, 2004 How do you convert mpg into miles per litre as all garages are in litres now, so all this talk about a G60 doing 28 mpg, etc is confusing, how many miles for us thick ones, ME, per litre. Someone please give me a clue, nicely please :0) Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 5, 2004 Does the G60 have a fuel cut off switch and if it does how can you test this is working (if it does have one) cheers[/quote There is an over run cut off switch on the G60. The same switch brings in the idle stab. If you have an air/fuel ratio meter fitted you can see when it is cutoff and when it comes back in. I don't think this would be the cause of bad consumption. More likely is a duff co probe.. Gavin Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 5, 2004 How do you convert mpg into miles per litre as all garages are in litres now, so all this talk about a G60 doing 28 mpg, etc is confusing, how many miles for us thick ones, ME, per litre. Someone please give me a clue, nicely please :0) 4.54 litres to the gallon. Divide the amount you put in, by 4.54 to give gallons and Bob's your uncle. 45 litres is near enough 10 gallons. Gavin Quote Share this post Link to post Share on other sites
