Purn1 0 Posted July 1, 2008 Hey there. Only just bought my corrado so a little new to things. The sunroof will only open approx 1inch. It opens fine in the tilt position though. The motor completely stops once its got as far as it will go and doesn't labour or struggle. I removed the whole sunroof earlier today and wondered if lubing up the cables and mechanism would help. Only problem is i cant get the thing open!! Any way i can open it manually? Cheers, Chris. Quote Share this post Link to post Share on other sites
skinnyman9000 0 Posted July 6, 2008 The motor will only turn so far in each direction, it could be possible then on the slide function the motor has reached the end of its travel. You can dismantle it and play around with the motor to ensure that it has enough travel in either direction to both tilt and slide it. I also believe that somewhere on the motor mechanism you can wind it round with an allen key Quote Share this post Link to post Share on other sites
Bigbadger 0 Posted July 28, 2008 Better than that, the allen key is supplied and fitted onto the sunroof motor. :) Quote Share this post Link to post Share on other sites
