Purn1 0 Posted July 10, 2008 Hello people. Right, ive got a 1991 1.8 16v, only recently just bought it. Ive had a problem with very damp/wet carpets. I located a leak in the boot, the little blue grommets on the badge had come off. Then the sunroof was leaking, made sure the drain tubes were clear and they were. Turned out the mechinism in the cassette had shattered causing a half inch gap that i couldn't see. Now ive found another leak. Im a little stuck on this one so some advice would be very gratefully received: Both the doors are are leaking onto the carpets throught the bottom. Not sure why... New seal maybe? Could the doors need adjustment? Thanks for you time, Chris Share this post Link to post Share on other sites
VR6 0 Posted July 10, 2008 Can we stick to your existing thread please? viewtopic.php?f=3&t=70203 Thanks Share this post Link to post Share on other sites
