Martyn_McG
vr6 aux drive belt problem
i have a squeak comming from around the aux drive belt area and i have decided its the tensioner wheel bearing from other posts i have read, i also got the bearing needed to replace it from the knowledge base article, but my question is before i start replacing it can anybody confirm if when i put it back together i will have to set the tension or is it none adjustable?
i ask because i dont want to drive round in fear that its going to be to tight and snap or loose and fall off!!
many thanks!!! better to clear these things up before i start pulling things apart and realise i cant finish the job, then i normaly :censored: :bad-words: :p :censored: :mad2: with a spanner :D
