Bups 0 Posted July 17, 2008 One for the wiring experts, Iv got a complete one touch window loom from a late rado and wanted to know what wires connect where, like light illumination/permanent 12v/negative etc.. Here are a few pics the wiring: Here is a Red wire which i think will be perm 12v, a brown/white, a red/black, a red/brown and a red/yellow which i have no idea what they are for. Here is a long brown/white There are two sets of these and im thinking they go the window regulators, a set for the drivers window and a set for the passenger window. The also appears to be a red/brown & black/yellow wire leading into a plug which im not sure about either. Any help to help me wire this in will be greatly appreciated :) Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 17, 2008 do you not have the connector blocks that plug into the back of the factory door switches? I have a passat and corrado loom at home and a bunch of switches and connector plugs hacked off passat looms, it was easy enough to get the whole lot working with a spare car battery the control box and two spare doors I have in the garage, just to test everything would work when installed. I can take some pics of the loom and connector/switch wires if you like, but can't remember how to wire off the top of my head. The passat haynes manual had pretty much all the info I needed in the wiring diagrams. The important thing for me was that the control box system has one fewer wire to each window switch compared to a direct wired system as you are jsut sending a signal to the box, not directly powering the window motors through the switches. Quote Share this post Link to post Share on other sites
Bups 0 Posted July 18, 2008 Yes i have all the connector blocks, its all uncut and ready to fit its just the wiring in the pics im unsure of. Quote Share this post Link to post Share on other sites
Bups 0 Posted July 20, 2008 If knobody knows then where can i get a wiring diagram for the rado windows? Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 30, 2008 pink passat 1988-92 Haynes manual (out of print I think but pop up on e-bay, car boots etc), bit confusing as the diagrams cover 4 door electric window circuit, but I worked it out easily enough from the haynes diagrams and I'm no electrician :) Quote Share this post Link to post Share on other sites
