radness
Reverse light on
Guys, where do i need to check to fix my reserve lights? both are on as soon as i turn the ignition on, they also stay on when in reverse too, it seems something is shorted somewhere but i dont know where to check, already took the rear clusters apart. :brickwall:
Check the reverse light switch on-top of the gearbox. It's a small plastic box with a 2 wire plug going into it just above where the gear selector cables connect.
Try simply disconnecting the plug to start with, and see if the reverse lights go out.
