raddo_tom
I'm going to regret this for the rest of my life.....
How the HELL do I change my drivers side headlight bulb??
Infact HOW DO I GET THE HEADLIGHT OUT???
Thank you for any help.... (I'm going to hide and prepare to be ridiculed)
taking the headlight out is easiest way i find.
just undo the two screws on the top that you can see, then there is a circle shaped hole in the slam panel, shine a torch down there and you will see the other screw :)
thankyou times a million!
Got headlight out changed bulb... still only working on dipped
tried removing other headlight plugged that in to faulty side.... still only dipped.
panic set in! (thinking wiring etc etc)
stood pacing like an idiot in front of partially stripped car....
Flatmate toddled along and said check the fuse... IT WAS BLOWN!
WOOOHOOOO! going to fit new fuse now....
ok mr attitude.... :lol:
I didn't get the wallet just a load of receipts and a v5....
Otherwise I would have consulted any documentation before posting on here.....
Don't worry dude, I didn't get the wallet with mine either, bought one off ebay!
Oh and changing the headlight bulbs is a lot easier if your tabs haven't broken off and been epoxyed on tenuously... that's the only thing stopping me swapping my main beam bulbs for Philips Bluevision! :|
