TITAN
elctrical fault
can anyone help my G60 has just stop working it has developed a
electrical fault i have no spark to the plugs also i can not hear the
fuel pump kick when i turn the ignition on i have found i broken
fuse type wire on a module that near the expansion tank not sure what
this unit is for, can anyone give me some pointers to what this unit for
and there are no blown fuse but did find a relay with a number 32 on it
that was very hot?? .
many thanks. ( before i have to get the auto electrician out ££££ )
Hi TITAN,
Any chance you could post a couple of pics of the suspect items? Can't quite work out which bits you're talking about...
I Cant do the pictures juust yet but ill try. had an auto electrian out he found inj relay inop
and he could not do a full test on the ECU as he did not the program to test!
The fuse bored all ok and he said the ECU is sending msg to the inj-relay?!!?
so he said ! . thanks for all your help ill keep u posted
cheers :D
