JMC
Any interest in ported/flowed G60 throttle inlets?
As the title says really. After porting and flowing my thottle, I was wondering whether any G60 owners would be interested in having the inlets to their throttle bodies flowed/ported?? If you've looked at the inlet there is a thick lip on the edge of the inlet which does not do anything for air flow. Also there is a shoulder about an inch inside which again makes for poor air flow. I can flow the inlet, and remove most of this shoulder, and smooth out the inside of the body. Below is a pic of one in the process of being done at the moment, just ready to be smoothed....
If there is any interest in getting it done, I can offer this flowing services for £25 (along with the inlet side of your thottle body to be returned to me when you have swapped them over). Also I can remove the tube going to the carbon cannister if you've had yours taken out (saves the need to have a length of tubing with a bolt in the end to seal the gap). Let me know if you're interested :D
No interest at all in these then - bit surprised, but heh thought I would check...
i could intrested in one when i get back from the germany trip
Ok mate, let me know when you get back :D
