stevw1
NO REVERSE LIGHTS !
Hi Guys (n Girls :camp: )
Seems all who have reverse light problems are those who's lights stay on. Mine won't :shock:
Have checked the bulbs and the fuses,even the connector on the g/box seems ok.But still no reverse lights when i select reverse gear :scratch:
Is there something else i need to look at? I know theres a small connection in front of the gears stick,under the cover,but what do i need to do to check it??
:help: Steve......
Try shorting the plug on the gear selector tower to see if they come on...
The connection under the gear lever cover is for power or VagCom.
How? FORGIVE ME IF I'M BEING THICK!!
What if this works?
Steve........
What if this works?
Steve........
ANYONE :wave:
Small length of wire with 1cm or so of the insulation peeled back on both ends. Just Remove the plug from the gearbox and connect the two pins in the plug together with the section of wire. Basically simulates engaging reverse.
Reverse lights 'should' come on.....and if they do it's your reverse light switch on the gb that's dead.
