jimhoughton 0 Posted October 7, 2008 Hi - I've just joined the forum and found what I thought was the answer to my 1993 2.0 16v's issue. The hazards and the indicators weren't working - I found a guy who'd had the same problem, replaced the relay and it all worked.....for about 5 minutes! Then the same relay went - I've no idea where to start - anyone any ideas on what might be causing the relay rather than the fuse to blow? Thanks so much in advance. Quote Share this post Link to post Share on other sites
