Zeakuole 0 Posted October 8, 2008 ok so i ended up spinning my car into a curb and ended up snapping off-side stub axle/hub and disc and ruining my Audi A3 Turbo wheel (the fat 5-spoke ones) which has left me in an interesting position, i really like the Borbet type A and much prefer the super deep dish 9" ones, however i have heard that you cannot fit the 9"s to the front on VR6s (which i have) does anybody know if it is possible for 9" all around or will i have to go for the 7.5" fronts and 9" backs? thanks mark PS: anybody driving in Cardiff, becareful at St. Andrews Place, travelling Cathays to town under the rail way when its wet. =p Quote Share this post Link to post Share on other sites
M15 VW 0 Posted October 9, 2008 Yes you can get 9s on the front on the vr6s. You may need spacers though. Quote Share this post Link to post Share on other sites
Zeakuole 0 Posted October 9, 2008 ok thanks you know what kind of overlap from wheel to arch will be? Quote Share this post Link to post Share on other sites
M15 VW 0 Posted October 10, 2008 I shaved my front caliper carriers down to get rid of the spacers on the front of mine and my fronts are only 7.5s but this will also help you. Is your corrado lowered? If so then the overlap will be a problem due to rubbing. Have you had anything done to your front arches? Quote Share this post Link to post Share on other sites
ebby 0 Posted October 10, 2008 I shaved my front caliper carriers down to get rid of the spacers on the front of mine and my fronts are only 7.5s but this will also help you. Is your corrado lowered? If so then the overlap will be a problem due to rubbing. Have you had anything done to your front arches? I have a set of 7.5s and was going to use spacers when i get round to fitting them.. how easy is it to get the front calipers shaved down and where would do this? a normal garage? and is it still safe and MOT legal etc? cheers Quote Share this post Link to post Share on other sites
M15 VW 0 Posted October 13, 2008 I shaved my front caliper carriers down to get rid of the spacers on the front of mine and my fronts are only 7.5s but this will also help you. Is your corrado lowered? If so then the overlap will be a problem due to rubbing. Have you had anything done to your front arches? I have a set of 7.5s and was going to use spacers when i get round to fitting them.. how easy is it to get the front calipers shaved down and where would do this? a normal garage? and is it still safe and MOT legal etc? cheers it is safe and my corrado just passed an mot so yeh its fine do it yourself with a file Quote Share this post Link to post Share on other sites
Zeakuole 0 Posted October 20, 2008 heya thanks for replies, been away for a while. thats good with the filing down of calipers, but yeah its been lowered 60mm i think, done by previous owner. which i can see will cause a bit of problem with rubbing. after a while of thinking, i'm pretty sure i'll be going with the 7.5s on the front. will make things easier and they're still more than wide enough :D thansk everyone and oh yeah glad to say back on the road now. not too bad only cost £350, just need to get arch repainted after it was torn out :( Quote Share this post Link to post Share on other sites
M15 VW 0 Posted October 30, 2008 good choice on the 7.5s on the front and 9s on the back :) Quote Share this post Link to post Share on other sites
