taffyjenks 0 Posted October 17, 2008 I own a 1990 VW Corrado 1.8 16v and about 10 months ago I had a problem with the ignition switch so I replaced it with a genuine VW part.Recently I have had exactlly the same symptoms so I painstakingly removed everything again and replaced the switch again however the problem still exists.The vehicle is ftted with a Cat 1 alarm and immobiliser.The ignition lights come on but as soon a you turn the key that extra turn to engage the starter nothing happens.I have tried this with both the key in the ignition and with the switch removed.Does anyone have an idea what It could be.I removed all the plugs prior to replacement but I did attach the main plug to the switch.I assume the other plugs are just for indicators etc.All help greatly appreciated as I am now pulling out what little hair I have. Thanks Tony Jenkins. p.s lovely cars many problems. Quote Share this post Link to post Share on other sites
weetos 0 Posted October 18, 2008 sometimes the connectors gets pushed out the back of the sockets when plugged back in (barbs aren't strong enough). does the fuel pump prime? if its the later sounds like immobiliser problem :bad-words: Quote Share this post Link to post Share on other sites
mattkh 0 Posted October 18, 2008 The ignition lights come on but as soon a you turn the key that extra turn to engage the starter nothing happens. Hi Clean and tighten the spade connector to the starter solenoid. Oh, and get this thread moved to the engine section. Quote Share this post Link to post Share on other sites
taffyjenks 0 Posted October 18, 2008 cheers folks will have a go this morning Tony Jenkins Quote Share this post Link to post Share on other sites
taffyjenks 0 Posted October 18, 2008 Cleaned and tightened the spade connector to the solenoid.Guess what started first time.Thanks a million. Tony Jenkins now happy rado owner. Quote Share this post Link to post Share on other sites
Pondy_p 0 Posted November 16, 2008 Hi I have this problem - I dont think it is such an easy fix tho' - are there any other suggestions?? dead starter motor? Quote Share this post Link to post Share on other sites
mattkh 0 Posted November 17, 2008 Hi Take the starter out, clean it up, test it and put it back. Quote Share this post Link to post Share on other sites
Pondy_p 0 Posted November 18, 2008 Thanks for post, sounds easy.... think will try cleaning it up in place. the Bentley manual warns of engine/gearbox alignment shifting if starter is removed?! is this an over cautious statement? perhaps somehting best left to a professional. Quote Share this post Link to post Share on other sites
