vrtoad
fuel pump relay
hello ive also got another vr6 problem which i cant find out much about. sometimes it wont start - ive got the cap off the fuel pump relay and i can see that the times the car doesnt start its because the relay isnt connecting. it only deos it sometimes but ive tried 3 different relays and i keep gettin the same problem, which leads me to beleive its not the relay but something before that which controls it. when it doesnt start i have to keep turning the ignition on and off and watching for the time the relay clicks - then it starts
anyone else had similar or able to help??
Hi
Please please put up a picture of the relay without the cap.
What's going on? Are you going to turn out to be some sort of filthy deviant making jokes about sleeping with animal's and Supercharged's family? I hope not. I'll be redundant otherwise. :(
I had this problem a while back. Found that it was actually the ecu relay which wasn't closing, which in turn caused the fuel pump relay not to connect. Cleaned all the contacts up and it's worked fine ever since.
