KipVR
Cold air feed on battery side
Did VW do any kind of cold air feed on any of the Corrado models for cold air on the passesnger side?
I'm looking for something that would copy the VR6 feed from under the headlight but on the other side to supply air to my Airbox which is now on the passenger side (R32 conversion), I can make one but I just thought I'd check VW didn't already make one....Anyone? :shrug:
You can use the Audi pipe that joins to the Audi airbox, then attach some ducting onto that round the side of the battery to the front.. If you've got an R32 airbox, then presumably an R32 will have a similar feed pipe to the airbox?
