kevjenkins
oil switch
could someone please tell me what colour the wire should be under the bonnet and where it should be located for the oil light (dashboard) g60
Not sure of the colours off the top of my head but your looking for 2 spade connectors with a plastic insulator that sit ontop of the oil filter housing...
One is pressure and one is temp, you have to open up the spade slightly if you replace these as the new ones are slightly different.
I may be wrong but temp sender is located behind the head.
Those 2 senders you say are one for high oil pressure, and one for low oil pressure.
