dreamer
16v 4 branch
im in the process of changing my 1.8 kr into a 9a
i would like to fit a 4 branch for that extra breathing just have 2 questions
1. which mainfolds fit? any 16v? 8v? or rado only one's?
2. wheres the best place to get one from cus could do with it by a week on sat?
thanks dreamer
Hi there ,I used to have a 2.0 16v raddo and i fitted a four branch which i got from ebay , it was easy fitted but only down side was i had to bore a hole and thread the o2 sensor. it made a great difference and far better throttle response. the four branch was £160 if i can remeber correctly .
hope this helps
the golf2 16v/jetta and passat 16v as well as the Corrado 1.8 and 2L 16v all use essentially the same manifold, with the 9A cars using a different shorter downpipe with no integral silencer as they use KE jetronic with lambda needing a probe fitment (as mentioned), they also have a cat instead of the integral silencer.
but don't discount porting and polishing a standard 16v cast iron exhaust manifold, that can give good results and you are assured of no heat/noise/cracking problems associated with some stainless all in one downpipe and manifolds.
