jackflash
Scuttle panel removal
Is the scuttle panel bonded to the windscreen as well as being screwed and clipped down? Been trying to remove it but I'm a bit worried about snapping it if I apply any more force to it...
Yep, bonded on as well. They get very brittle with age so odds are quite good for snapping something!
As I understand it, It shouldn't be bonded but lots of windscreen companies, when replacing Corrado windscreens, will take the easy option and bond it down as the clips tend to break when it's removed unless it's done with care.
So - all I can say is expect the unexpected and be ready to look for one off a Corrado being broken if you snap it :)
