cope
More little problems keep popping up G60.. hmmmmm
Hi again,
As i get more and more used to this car, i seem to have more and more questions, and possibly problems.
Here are a few new ones i seem to have come accross.
Cruise control appears not to work. I try to set it at lets say 120Km/h and when i let go of my gas pedal, it doesnt stick or stay.
Starter doesnt turn over when its cold. Im in Canada so the temps are currently around -8 to -20 degrees celcius.... Car starts when it warm with no problems. What happens is that i get a spinning sound and thats all. Sometimes i get nothing at all. If i retry 2-4 times, the car starts up fine with no problems.
Heres another one, When its cold.... i cannot change the gear into reverse, when i try to, it goes into 1st instead. It feels like its going into reverse, i press down and up, but its in 1st, Like i said, when its warms up, i can then go into reverse with no probs at all.
2nd gear when cold seems to grind a tad, its not smooth. All the other gears are nice smooth and go in very easily. 2nd gear when the car warms up is better, but still has that little grind feeling with the shifter when i change to 2nd from 1st or downshifting from 3rd. All other gears are hunky dorey. Clutch was changed a few weeks back, but it was doing it still prior to being changed so i assume it not it but maybe a transmission problem?
Hmmm, oh, when i put my flashers on, is it normal for it not to turn off on their own? I have to manually turn them off, kinda a pain in the arse if you know what i mean. Sometimes i forget to turn them off, dohhhh.
I thinks thats it.... seems like stupid stuff actually, but stuff i dont know how to fix ): Im a learning though thanks to all you helpful people (:
