radness
Windows - Possible attempted breakin
Since I've been working on the corrado i've had it parked at a mates house who has a big drive..etc
he said that lastnight the alarm went off in the early hours of the morning - i left him with a key
today i noticed that the drivers window was miss-aligned, so much so that there was an inch between the door frame and the glass (the glass was also out of the frame and poking 5mm out from the door. I can put the window up if i hold it in place while winding it up. Once it's up and i go over any bumps i can hear it knocking loudly like it's almost about to break. Something tells me this could just be my luck, but the fact that it was the drivers door (furthest away from the house) and the alarm going off at a usual time for criminal activitey (4-6am) it just seems like it was a break in attempt :mad2:
So my question is; is this a known entry method on our cars? If so is there anyway to prevent this? Also, i assume something has now been broken in the car and i need to fix whatever has been disconnected/broken in the door. IS access just as simple as screwing the inside door cover off?
AS always, thanks for any replies or help on this ;)
