dgarwood07 0 Posted January 26, 2009 My C\L has stopped working all together! Even with the key. I have always just used the remote C\L (Hornet alarm ). The alarm works but the C\L aint. I aint gotta clue where to start or what could cause this?? Any ideas? Thanks!! Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 26, 2009 there is pump in the rear of car that controls the locks it could be that Quote Share this post Link to post Share on other sites
dgarwood07 0 Posted January 26, 2009 3corsameal said: there is pump in the rear of car that controls the locks it could be that Oh is there! Where abouts? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 26, 2009 pinched from someone elses post viewtopic.php?f=2&t=5088&p=47196&hilit=central+locking+pump#p47196 Quote Share this post Link to post Share on other sites
dgarwood07 0 Posted January 26, 2009 3corsameal said: pinched from someone elses post viewtopic.php?f=2&t=5088&p=47196&hilit=central+locking+pump#p47196 Cool! Thanks for that! If its workin will it make much noise? Is there an easya way to test if its workin?? :D Quote Share this post Link to post Share on other sites
nick vr6 0 Posted January 27, 2009 Do your windows work? If not it is probably just a fuse gone. Check the fuse on its own above the bank of fuses. Worth a try , and free :D Quote Share this post Link to post Share on other sites
dgarwood07 0 Posted January 27, 2009 nick vr6 said: Do your windows work? If not it is probably just a fuse gone. Check the fuse on its own above the bank of fuses. Worth a try , and free :D My windows are still workin m8 Quote Share this post Link to post Share on other sites
dgarwood07 0 Posted February 18, 2009 Changed pump still dont work!!!!!!!!!!!!!! :bad-words: :bad-words: What do i try next??? Quote Share this post Link to post Share on other sites
KIPVW 0 Posted February 18, 2009 I think it could be that one of the air lines has either detached itself or you have a leak somewhere, can you hear it when you press the button on the remote? Might be door cards off to see what you can see but get some polythene and some evo stick wet grip adhesive first as you need to see behind the membranes :brickwall: Quote Share this post Link to post Share on other sites
dgarwood07 0 Posted February 18, 2009 KIPVW said: I think it could be that one of the air lines has either detached itself or you have a leak somewhere, can you hear it when you press the button on the remote? Might be door cards off to see what you can see but get some polythene and some evo stick wet grip adhesive first as you need to see behind the membranes :brickwall: I cant hear anythin comin from the pump! :( Quote Share this post Link to post Share on other sites
KIPVW 0 Posted February 18, 2009 You sure its not one of the relays then near the fuse box? I dont know myself but i'm sure there is one somewhere so hopefullly someone will confirm. You plugged it in didnt you???? daft question but i forgot when i looked :lol: Quote Share this post Link to post Share on other sites
dgarwood07 0 Posted February 18, 2009 KIPVW said: You sure its not one of the relays then near the fuse box? I dont know myself but i'm sure there is one somewhere so hopefullly someone will confirm. You plugged it in didnt you???? daft question but i forgot when i looked :lol: Yeah i plugged it :D I aint checked the relays tho?? :cuckoo: Quote Share this post Link to post Share on other sites
oldskoolkool 0 Posted February 18, 2009 has any one got a wireing diagam as im not sure which relay it is :confused4: what feeds should be at the pump and is it switched earth im guessing not but just wondering ???? sorry hijacking lol Quote Share this post Link to post Share on other sites
