falcodub
g60 wiring advice
I am about to fit a g60 engine (out of a golf g60) into my 89 mk2 golf gti 8v and i am unsure if i can just change the main engine looms as i thought i had 90 spec fuse box. But as my car is pre aug 89 i don't think i have. Hazard light on dash.
Don't tell me i'm gonna have to change the fuse box!
The g60 ecu wiring is all stand alone but it has a 5 pin connector that i am unsure what to do with. How do i wire this up?
What are the differences in pre 90 spec and post 90 wiring?
You would need the central electric fusebox for the g60 loom to plug straight in. Theres a wiring diagram on vortex, shouldnt be that complicated
Can i fit a corrado g60 fusebox then? Is there no other way of getting this in my car without changing the fuse box?
What about the 5 pin connector within the g60 loom that goes to what should be a corresponding plug near ecu?
