corradog60stage4
DIY changing the offset on my wheel to fit the corrado
Stock BBS RS001 are 15 X 7 ET 25 with a 4X100 bolt pattern.
OEM outer is 1.0 and OEM inner is 5.5.
47b8db01b3127ccec47d431f907f00000056100QcOWzNuxcMQe3nww
SAE to metric conversion
ET is measured in mm
1 inch = 25.4mm
Back to my RS001 wheels I have that I will convert them to 16 inch wheels. People are still very confused as how to calculate or have an idea of offset.
First positive offset can be reduced with the use of adapters and spacers but
what alot of people that do not know that you cannot use adapters or spacers to increase the offset of wheels. The only way is the mill the hub surface of the wheel. I had a few yahoos telling me that with ET 10 wheels I would need spacers to make the offset positive. This is wrong.
Going with spacers makes the wheel poke out which is undesirable for wide wheels.
What I like about my RS001 wheels is I can alter the offset anyway I please without the use of adapters or spacers.
OEM the RS001 comes with a 1 inch outer and a 5.5 inch inner thus giving you a 15 X 7 wide wheel with an ET of 25.
To keep the same ET of 25 but going wider you can put 1.5 outer and 6.0 inner or 2.0 outer and 6.5 inner. both combinations will give you ET 25 but the first will give a 8.0 wide wheels while the second a 9.0 wide wheels.
Leaving the 1.5 outer and 6.0 inner you can put just a wider outer 2.0 and leave the 6.0 inner to get an ET of 12.3. some may ask how you get ET 12.3? When you add width on the outer you will reduce the offset by the same amount. so you add 0.5 inch which is equivalent to 12.7mm gives you ET 25 - 12.7 = ET 12.3. You want a wider lips like 2.5 with the 6.0 inner the ET will be ET 25 - 25.4 = ET -0.4.
you can leave the outer alone and increase or decrease the width of the inner barrel as well. Let say you have the 1.5 outer and 6.0 inner ET 25 you want to increase the inner to 6.5 so the equation will be ET 25 + 12.7 = ET 37.7.
So I got two 1 inch , four 1.5 inch, four 2.0, two 2.5 inch outers, four 6.0 inner and two 6.5 inner to play with.
bbs instar
47b8db01b3127ccec47cf365b01100000056100QcOWzNuxcMQe3nww
different width lips
47b8db01b3127ccec47dee7451ea00000056100QcOWzNuxcMQe3nww
47b8db01b3127ccec47c627671e200000055110QcOWzNuxcMQe3nww
47b8db01b3127ccec47dd161117800000056100QcOWzNuxcMQe3nww
47b8db01b3127ccec47d157d110600000056100QcOWzNuxcMQe3nww
47b8db01b3127ccec47db5f711dc00000056100QcOWzNuxcMQe3nww
47b8db01b3127ccec47d58e7512200000056100QcOWzNuxcMQe3nww
different width inners
47b8db01b3127ccec47c83a631da00000056100QcOWzNuxcMQe3nww
47b8db01b3127ccec47dd8c9514c00000055130QcOWzNuxcMQe3nww
47b8db01b3127ccec47c8040f09500000055110QcOWzNuxcMQe3nww
47b8db01b3127ccec47cfec3f02900000055110QcOWzNuxcMQe3nww
47b8db01b3127ccec47d787751a200000056100QcOWzNuxcMQe3nww
47b8db01b3127ccec47c8679f0af00000056100QcOWzNuxcMQe3nww
new lips and barrels sitting in the garage for years.
47b8db05b3127ccec4650a03b20900000046100QcOWzNuxcMQe3nww
some rs bolts and nuts to hold the wheels temporarily together
47b8db05b3127ccec465e347f2a100000045110QcOWzNuxcMQe3nww
47b8db05b3127ccec464efafd20300000045110QcOWzNuxcMQe3nww
47b8db05b3127ccec465a388737e00000045110QcOWzNuxcMQe3nww
2 inch lip
47b8db05b3127ccec464ae64134000000045110QcOWzNuxcMQe3nww
47b8db05b3127ccec465851af2cf00000045110QcOWzNuxcMQe3nww
plaaced instar over barrel first.
47b8db05b3127ccec464a28613a400000046100QcOWzNuxcMQe3nww
lip goes over the instar
47b8db05b3127ccec464aa8d929b00000045110QcOWzNuxcMQe3nww
bolts and nuts
47b8db05b3127ccec465fe77b20700000045110QcOWzNuxcMQe3nww
47b8db05b3127ccec46416d413ac00000046100QcOWzNuxcMQe3nww
looks pretty shiney
47b8db05b3127ccec46546a033bc00000046100QcOWzNuxcMQe3nww
47b8db05b3127ccec4642fafd26300000045130QcOWzNuxcMQe3nww
47b8db05b3127ccec4656698339400000045110QcOWzNuxcMQe3nww
47b8db05b3127ccec4651d85732c00000045130QcOWzNuxcMQe3nww
16X 8.5 wide
47b8db05b3127ccec4640816925100000046100QcOWzNuxcMQe3nww
6.0 inch inner barrel clears with 5-6mm before hitting the spring.
47b8db05b3127ccec464cd5153dc00000046100QcOWzNuxcMQe3nww
47b8db05b3127ccec4651ba0730a00000046100QcOWzNuxcMQe3nww
47b8db05b3127ccec465c3abf25d00000045110QcOWzNuxcMQe3nww
looks like going with a 2 inch outer is too wide and will give me rear wheel arch issues.
47b8db05b3127ccec4652176f2f100000045110QcOWzNuxcMQe3nww
47b8db05b3127ccec4642b62539c00000046100QcOWzNuxcMQe3nww
47b8db05b3127ccec4656ea3b29b00000046100QcOWzNuxcMQe3nww
47b8db05b3127ccec464eae192d700000045110QcOWzNuxcMQe3nww
47b8db05b3127ccec465aba4735600000046100QcOWzNuxcMQe3nww
47b8db05b3127ccec46524aab2b700000045130QcOWzNuxcMQe3nww
47b8db05b3127ccec46452e1928b00000045110QcOWzNuxcMQe3nww
47b8db05b3127ccec4651deaf27300000046100QcOWzNuxcMQe3nww
47b8db05b3127ccec465fcd3339200000045110QcOWzNuxcMQe3nww
Wow, that was a lesson!! :cuckoo:
But, completley wrong im affraid, if you add a certain amount to one side of a wheel it changes the offset (ET) by half that amount, eg, you add 0.5" (12.7mm) to the ouside of a wheel, the offset reduce's by 6.3mm, think about it, offset is the distance from the MIDDLE of the wheel to the mounting face, you add to the outside of a wheel that distance changes but the middle of the wheel moves also doesn't it!
Hey buddy you forgot to read this :cuckoo:
so if you read adding 0.5 + 1.0 to the outside = 1.5 and adding 0.5 + 5.5 to the inside = 6.0 the ET remains the same at 25 but the wheel becomes 15 X 8.
I wonder who's :cuckoo:
LOl, what you quoted there is true, who's saying it isn't??
My point is what you've said here....
This is'nt true, when you add width to an outer it does'nt change the offset by the same amount.
A wheel made from your centre with a 6.0 inner and a 2.5 outer as you mentioned would be ET 12.3 btw. (your wheel with a 1.5 outer and 6.0 inner is still ET 25 as you say, you add 1" to the outside to give 2.5 outer and 6.0 inner, ET is the original 25mm minus half what you've added (25 - 12.7 = 12.3) , because you add 1" to the outside of the wheel, the midddle of the wheel moves by half an inch (12.7).
